My Xiaomi Redmi Note 11 Pro 5G uses a large amount of mobile data
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press Wi-Fi assistant.
Press the indicator next to 'Stay connected' to turn the function on or off.
If you turn on the function, press the indicator next to 'Ask permission for using mobile data'.
Press Got it.
Press Notifications & Control centre.
Press App notifications.
Press Location.
Press the indicator next to 'Location access' to turn the function on or off.
Press App access to location.
Press the Return key twice.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press DONE.
