My Xiaomi Redmi A3 uses a large amount of mobile data
Press App notifications.
Press the drop down list.
Press Location.
Press App location permissions.
Press the Return key twice.
Press Location Services.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
