My Xiaomi Redmi 9AT uses a large amount of mobile data
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press Wi-Fi assistant.
Press Select best networks automatically.
Press the indicator next to 'Select best networks automatically' to turn the function on or off.
Press Location.
Press the indicator next to 'Location access' to turn the function on or off.
Press App permission.
Press the Return key twice.
Press Play Store.
Press Auto-update apps.
Press DONE.
