Top queries
Device help
Managing your account
Other ways to get help
Press Music and go to the required audio file.
Press arrow left to go to the previous audio file.
Press the playback mode icon repeatedly to select the required setting.
Press the playlist icon.
Press the required audio files to add them to the playlist.
Press New.
