I have problems receiving voice calls on my Xiaomi Redmi 9AT
Press the phone icon.
Press Calling accounts.
Press Call-forwarding settings.
Press the required SIM.
901
901
Key in 901 and press Turn on.
If you divert missed calls, you need to select a delay for the divert. Press the required delay and follow the instructions on the screen to select a delay for the divert.
Press Turn off.
Press Advanced settings.
Press Call barring.
