I have problems sending and receiving emails on my Xiaomi Mi Mix 3
Press Sync.
Press Add account.
Press Personal (POP3).
Press NEXT.
Press NEXT.
Press the drop down list below 'Delete emails from server'.
Press When I delete from Inbox to delete emails on the server when you delete them on your phone.
Press NEXT.
Press NEXT.
Press the drop down list below 'Sync frequency'.
Press NEXT.
Press Your name and key in the required sender name.
Press NEXT.
Press Google.
Press Gmail.
Press the profile icon.
Press the new email icon.
Press the required contact.
Press the attachment icon.
Press Attach file.
Press File Manager and go to the required folder.
Press the required file.
Press OK.
Press Sync.
Press Add account.
Press Personal (IMAP).
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
