My Sony Xperia XZ1 Compact uses a large amount of mobile data
Press Network & Internet.
Press Wi-Fi.
Press Wi-Fi preferences.
Press the indicator next to 'Auto network switch' to turn the function on or off.
If you turn on the function, press ENABLE.
Press Apps & notifications.
Press Configure notifications.
Press Apps.
Press Play Store.
Press Auto-update apps.
To turn off automatic update of apps, press Do not auto-update apps.
To turn on automatic update of apps using mobile network, press Auto-update apps at any time. Data charges may apply..
To turn on automatic update of apps using WiFi, press Auto-update apps over Wi-Fi only.
