Press Nofications.
Press the indicator next to 'Block all' to turn the function on or off.
Press Apps.
Press Play Store.
Press Auto-update apps.
Press Do not auto-update apps to turn off the function.
Press Auto-update apps over Wi-Fi only to turn on the function.
