I have problems sending and receiving picture messages on my Sony Xperia XA2
Press Network & Internet.
Press Mobile network.
Press Access point names.
Press Name.
Press APN.
Press Username.
Key in o2wap and press OK.
Press Password.
Key in password and press OK.
Press MMSC.
Press MMS proxy.
Press MMS port.
Key in 8080 and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in mms and press OK.
Press Save.
Press Messages.
Press the new message icon.
Press the required contact.
Press the attachment icon.
Press Images and go to the required folder.
Press the required picture.
If you turn on data roaming, press OK.
