I have problems sending and receiving emails on my Sony Xperia XA2
Press Users & accounts.
Press Add account.
Press Exchange Services.
Press Email address and key in your email address.
Press NEXT.
Press NEXT.
Press POP3.
Press the field below 'POP3 server' and key in the name of your email provider's incoming server.
Press the drop down list below 'Delete email from server'.
Press When I delete from Inbox to delete emails on the server when you delete them on your phone.
Press NEXT.
Press the indicator next to 'Require sign-in.' to turn on the function.
Press NEXT.
Press SHOW MORE SYNC OPTIONS.
Press the drop down list below 'Automatically (Every 5 minutes)'.
To turn on manual retrieval of emails, press Manually.
Press the drop down list below 'Messages to sync'.
Press Sync email to turn on the function.
Press NEXT.
Press NEXT.
Press the field below 'Set account name (optional)' and key in the required name.
Press the field below 'Your name (shown on outgoing messages)' and key in the required sender name.
Press FINISH SETUP.
Press Apps.
Press the email account drop down list.
Press the required account.
Press the new email icon.
Press the required contact.
Press the attachment icon.
Slide your finger right on the screen and go to the required folder.
Press the required file.
Press Add account.
Press NEXT.
Press NEXT.
Press IMAP.
Press the field below 'IMAP server' and key in the name of your email provider's incoming server.
Press NEXT.
Press NEXT.
Press the drop down list below 'Automatically (Push)'.
Press the drop down list below 'Days to sync'.
Press NEXT.
Press NEXT.
Press FINISH SETUP.
