My Sony Xperia 5 II uses a large amount of mobile data
Press Apps & notifications.
Press SEE ALL APPS.
Press Location.
Press App-level permissions.
Press the Return key twice.
Press Advanced.
Press the indicator next to 'Improve Location Accuracy' to turn on the function. If you turn on the function, your phone can find your exact position using the GPS satellites, the mobile network and nearby WiFi networks. Satellite-based GPS requires a clear view of the sky.
Press the indicator next to 'Improve Location Accuracy' to turn off the function. If you turn on the function, your phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby WiFi networks.
Press Play Store.
Press Auto-update apps.
Press DONE.
