My Sony Xperia 10 VI uses a large amount of mobile data
Press Apps.
Press See all apps.
Press Location.
Press App-level permissions.
Press the Return key twice.
Press Location Services.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
