My Samsung Galaxy Z Fold6 uses a large amount of mobile data
Press Wi-Fi.
Press Intelligent Wi-Fi.
Press App notifications.
Press the drop down list.
Press Location.
Press App permissions.
Press the Return key twice.
Press Location services.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
To turn on automatic update of apps using mobile network, press Update all apps over Wi-Fi or mobile data.
To turn on limited update of apps using mobile network, press Update with limited amount of mobile data.
If you turn on limited update of apps via mobile network, your most used apps are automatically updated via the mobile network when no Wi-Fi networks are within range.
To turn on automatic update of apps using WiFi, press Update over Wi-Fi only.
