My Samsung Galaxy Z Flip3 5G uses a large amount of mobile data
Press Wi-Fi.
Press Advanced.
Press More.
Press the drop down list.
Press Location.
Press App permissions.
Press the Return key twice.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press DONE.
