I have problems sending and receiving picture messages on my Samsung Galaxy Xcover 5
Press Mobile networks.
Press Access Point Names.
Press the required SIM.
Press Add.
Press Name.
Press APN.
Press Username.
Key in o2wap and press OK.
Press Password.
Key in password and press OK.
Press MMSC.
Press MMS proxy.
Press MMS port.
Key in 8080 and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in mms and press OK.
Press Save.
Press Samsung.
Press Messages.
Press the new message icon.
Press the required contact.
Press the SIM icon to select the required SIM.
Press arrow right.
Press the picture icon.
Press the required picture.
Press Done.
Press the indicator next to 'Data roaming ‹SIM›' to turn the function on or off.
