I have problems making WiFi Calls on my Samsung Galaxy Xcover 5
Press the phone icon.
Press WiFi Calling.
Press Software update.
Press the Side key.
Simultaneously, press and hold the Bottom volume key and keep them both pressed until your phone restarts.
