I can't activate my Samsung Galaxy Watch7
If you can't activate your smartwatch before using it for the first time or after having restored it, there may be several causes of the problem.
Try activating your smartwatch later or when you're in another area.
Try activating your smartwatch later when you're in an area with better network coverage.
