You can use your smartwatch for navigation helping you find a certain destination.
Press the Google Maps icon.
Press the search icon.
Press the microphone icon and say the required destination.
Press the keypad icon.
Key in the required destination and press the search icon.
Press the required mode of transportation.
Follow the instructions on the screen to navigate to the selected destination.
Press Stop directions.
