How to select setting for dual SIM function on your Samsung Galaxy Tab S9 Ultra 5G
In addition to your normal SIM, you can also use an eSIM on your tablet. You can select which plan you want to use for calls, messages and mobile data. To select settings for dual SIM functionality, you need to activate your eSIM.
