My Samsung Galaxy Tab S9 Ultra 5G uses a large amount of mobile data
If your tablet uses a large amount of mobile data, there may be several causes of the problem.
Press Wi-Fi.
Press Intelligent Wi-Fi.
Press App notifications.
Press the drop down list.
Press Location.
If you turn on use of GPS position, your tablet can find your position using GPS. If you turn off the function, you can't use any GPS functions on your tablet.
Press App permissions.
Press the Return key twice.
Press Location services.
If you press the indicator next to 'Improve Location Accuracy' to turn on the function, your tablet can find your exact position using the GPS satellites, the mobile network and nearby WiFi networks. Satellite-based GPS requires a clear view of the sky.
If you press the indicator next to 'Improve Location Accuracy' to turn off the function, your tablet can find your exact position using the GPS satellites but it may take longer as there is no access to supplementary information from the mobile network or nearby WiFi networks.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
