Press Phone.
Press More settings.
Press Call forwarding.
Press Voice call.
Key in 901 and press ENABLE.
Press DISABLE.
Press and hold On/Off.
Simultaneously, press and hold the lower part of the Volume key and keep them both pressed until your tablet restarts.
Press Call barring.
Press the indicator next to the required barring type.
