I have problems checking my voicemail on my Samsung Galaxy Tab A 10.1 (2016)
Call 901 and follow the instructions to set up your voicemail. If you've previously deactivated your voicemail and want to reactivate it, call 1750 (free of charge when calling from your own tablet).
Call your own phone number from another device. Press # when you hear your voicemail greeting. You're asked to key in your voicemail PIN. Please note that you need to set a voicemail PIN before you can check your voice messages from another device.
The voicemail number is 901.
Call 901 and follow the instructions to activate your voicemail. If you've previously deactivated your voicemail and want to reactivate it, call 1750 (free of charge when calling from your own tablet).
Call 901 to check your voice messages when abroad. If you can't call 901, call 1780 instead (free of charge when calling from your own tablet) or call +44 7802 090 100 and wait until you receive a text message from O2 with the correct number. Please note that you need to set a voicemail PIN before you can check your voice messages when abroad.
