I have problems making WiFi Calls on my Samsung Galaxy S9+
Press Phone.
Press the indicator next to 'WiFi Calling' to turn the function on or off.
When WiFi Calling is active, the WiFi Calling icon is displayed.
Press Software update.
Press Download updates manually. If a new software version is available, it's displayed. Follow the instructions on the screen to update the phone software.
Press and hold On/Off.
Simultaneously, press and hold the lower part of the Volume key until your phone restarts.
