I have problems sending and receiving emails on my Samsung Galaxy S9
Press Cloud and accounts.
Press Accounts.
Press Add account.
Press Email.
Press Email address and key in your email address.
Press SIGN IN.
Press POP3 account.
Press the field below 'POP3 server' and key in the name of your email provider's incoming server.
Press the drop down list below 'Delete email from server'.
Press When deleted from Inbox to delete emails on the server when you delete them on your phone.
Press the indicator next to 'Authentication required before sending emails' to turn on the function.
Press SIGN IN.
Press Samsung.
Press Email.
Press the indicator below the required email account to turn the function on or off.
Press the Return key.
Press the required account.
Press the indicator next to 'Sync account' to turn on the function.
Press Account name.
Key in the required name for the email account and press OK.
Press Your name.
Key in the required sender name and press OK.
Press Sync schedule.
Press Set sync schedule.
Press Samsung.
Press Email.
Press the new email icon.
Press the required contact.
Press ATTACH.
Press OTHER.
Press My Files and go to the required folder.
Press the required file.
Press DONE.
Press SEND when you've finished your email.
Press Accounts.
Press Add account.
Press Email.
Press SIGN IN.
Press IMAP account.
Press the field below 'IMAP server' and key in the name of your email provider's incoming server.
Press SIGN IN.
Press Samsung.
Press Email.
Press Account name.
Press Your name.
