I have problems sending and receiving emails on my Samsung Galaxy S25 Ultra
Press Accounts and backup.
Press Manage accounts.
Press Add account.
Press Personal (IMAP).
Press Next.
Press Next.
Press the field below 'Port' and key in 993.
Press SSL/TLS.
Press Next.
Press the field below 'Port' and key in 587.
Press SSL/TLS.
Press Next.
Press Next.
Press Next.
