I have problems sending and receiving emails on my Samsung Galaxy S25+
Press Accounts and backup.
Press Manage accounts.
Press Add account.
Press Personal (IMAP).
Press Next.
Press Next.
Press the field below 'Port' and key in 993.
Press SSL/TLS.
Press Next.
Press the field below 'Port' and key in 587.
Press SSL/TLS.
Press Next.
Press Next.
Press Next.
