My Samsung Galaxy S25+ uses a large amount of mobile data
Press Wi-Fi.
Press Intelligent Wi-Fi.
Press App notifications.
Press the drop down list.
Press Location.
Press App permissions.
Press the Return key twice.
Press Location services.
Press Location Accuracy.
