Top queries
Device help
Managing your account
Other ways to get help
You can use multiple applications at the same time in split screen view.
Press the Application key to open the list of running applications.
To use split screen view, you need to have opened the required applications.
Press the first application and drag it to the top or bottom of the screen.
Press the second application.
The applications are now shown in split screen view and you can use both applications at the same time.
Press and hold the customise application window icon.
Drag up or down on the screen to adjust the application windows to the required size.
Press the menu icon at the top of the required application window.
Press the end icon.
