Press Call assist during a call.
You can have a phone conversation with another person in two different languages and have it translated as you speak. To use the function, you need to turn on Live Translate in Settings on your phone.
Press the drop down lists to select the required languages.
Say the required word or phrase and wait for the translation.
To exit Live Translation, press the stop translation icon.
Go to the required picture.
You can draw a circle around an object on a picture and search for the object on the internet. You can use the function in all apps that allow you to take screenshots. To use Circle to Search, you need to turn on the function in Settings on your phone.
Press and hold the Home key.
Draw a circle around the required object on the picture and wait for the search results.
Follow the instructions on the screen to use the search results.
Press the Return key to return to the picture.
Open a supported app, e.g. Messages.
Using AI, you can change the style of writing in your messages. The function works with all of Samsung's own apps as well as message and social media apps.
Create a new message and write .
Open the Voice Recorder.
Using AI, you can transcribe your dictaphone recordings.
Create a new recording or open a previously saved recording.
Press Transcribe and wait for the transcription.
To view a summary of the text, press Summary.
Press the Return key to save the changes.
