I have problems sending and receiving picture messages on my Samsung Galaxy S22 Ultra
Press Mobile networks.
Press Access Point Names.
Press Add.
Press Name.
Press APN.
Press Username.
Key in o2wap and press OK.
Press Password.
Key in password and press OK.
Press MMSC.
Press MMS proxy.
Press MMS port.
Key in 8080 and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in mms and press OK.
Press Save.
Press Samsung.
Press Messages.
Press the new message icon.
Press the required contact.
Press arrow right.
Press the picture icon.
Press the required picture.
Press Done.
