How to turn VoLTE on your Samsung Galaxy S22 on or off
When VoLTE is turned on, you can make phone calls via the mobile network using a faster and better connection. To turn on VoLTE, you need to select 4G (LTE) as network mode.
Check out nowWhen VoLTE is turned on, you can make phone calls via the mobile network using a faster and better connection. To turn on VoLTE, you need to select 4G (LTE) as network mode.
