I have problems making WiFi Calls on my Samsung Galaxy S10+
Press the phone icon.
Press the indicator next to 'WiFi Calling' to turn the function on or off.
Press Software update.
Press and hold On/Off.
Simultaneously, press and hold the lower part of the Volume key until your phone restarts.
