I have problems making WiFi Calls on my Samsung Galaxy S10
Press the phone icon.
Press the indicator next to 'WiFi Calling' to turn the function on or off.
Press Software update.
Press and hold On/Off.
Simultaneously, press and hold the lower part of the Volume key until your phone restarts.
