My Samsung Galaxy J6 uses a large amount of mobile data
Press Wi-Fi.
Press ADVANCED.
Press Play Store.
Press Auto-update apps.
To turn on automatic update of apps using mobile network, press Over any network Data charges may apply.
To turn off automatic update of apps, press Do not auto-update apps..
