I have problems making WiFi calls on my Samsung Galaxy J4+
Press Phone.
Press the indicator next to 'Wi-Fi calling' to turn the function on or off.
Press Software update.
Press Download updates manually. If a new software version is available, it's displayed. Follow the instructions on the screen to update the phone software.
Press and hold On/Off.
Simultaneously, press and hold the Bottom volume key until your phone restarts.
