Press Phone.
Press More settings.
Press Call forwarding.
Press Voice call.
Key in 901 and press ENABLE.
Press DISABLE.
Press and hold On/Off.
Simultaneously, press and hold the lower part of the Volume key until your phone restarts.
Press Call barring.
Press the indicator next to the required barring type.
