My Samsung Galaxy A55 5G uses a large amount of mobile data
Press Wi-Fi.
Press Intelligent Wi-Fi.
Press App notifications.
Press the drop down list.
Press Location.
Press App permissions.
Press the Return key twice.
Press Location services.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
