I have problems sending and receiving emails on my Samsung Galaxy A50
Press Accounts and backup.
Press Accounts.
Press Add account.
Press Email.
Press Other.
Press Email address and key in your email address.
Press Sign in.
Press POP3 account.
Press the field below 'POP3 server' and key in the name of your email provider's incoming server.
Press the drop down list below 'Auto delete from server'.
Press When deleted from Inbox to delete emails on the server when you delete them on your phone.
Press the indicator next to 'Require authentication to send emails' to turn on the function.
Press the first field below 'Require authentication to send emails' and key in the username for your email the email provider's outgoing server.
Press the second field below 'Require authentication to send emails' and key in the password for your email provider's outgoing server.
Press Sign in.
Press Samsung.
Press Email.
Press the indicator next to 'Show notifications' below the required email account to turn the function on or off.
Press the Home key.
Press the required account.
Press the indicator next to 'Sync account' to turn on the function.
Press Account name.
Key in the required name for the email account and press Done.
Press Your name.
Key in the required sender name and press Done.
Press Email sync schedule.
Press Set sync schedule.
Press Samsung.
Press Email.
Press the new email icon.
Press the required contact.
Press the attachment icon.
Press My Files and go to the required folder.
Press the required file.
Press Done.
Press Accounts.
Press Add account.
Press Email.
Press Other.
Press Sign in.
Press IMAP account.
Press the field below 'IMAP server' and key in the name of your email provider's incoming server.
Press Sign in.
Press Samsung.
Press Email.
Press the Return key.
Press Account name.
Press Your name.
