You can set your phone's alarm to wake you up or remind you of something at a certain time.
Press Clock.
Press the set new alarm icon.
Slide your finger up or down on the hour and minute numbers to set the required alarm time.
Press the required week days to select them.
Press the indicator next to 'Alarm sound' to turn on the alarm tone.
Press Alarm sound and follow the instructions on the screen to select the required alarm tone.
Press the indicator next to 'Snooze' to turn snooze on or off.
If you turn on snooze, press Snooze and follow the instructions on the screen to select the required settings.
Press Save.
Press the indicator next to the required alarm to turn the alarm on or off.
Press and hold the required alarm.
Press Delete.
