My Samsung Galaxy A12 uses a large amount of mobile data
Press Wi-Fi.
Press Advanced.
Press See all.
Press the drop down list.
Press All.
Press Location.
Press App permissions.
Press the Return key twice.
Press Play Store.
Press Auto-update apps.
Press DONE.
