Top queries
Device help
Managing your account
Other ways to get help
Press the phone icon.
Press Supplementary services.
Press Call forwarding below the required SIM.
Press Voice call.
Key in 901 and press Enable.
Press Disable.
Press the Side key.
Press Call barring below the required SIM.
