I have problems sending and receiving emails on my OPPO Reno4 Pro 5G
Press Users & accounts.
Press Add account.
Press Personal (POP3).
Press NEXT.
Press NEXT.
Press None.
Press the drop down list below 'Delete emails from server'.
Press When I delete from Inbox to delete emails on the server when you delete them on your phone.
Press NEXT.
Press None.
Press NEXT.
Press Notify me when emails arrive to turn the function on or off.
Press Sync email for this account to turn on the function.
Press NEXT.
Press NEXT.
Press Gmail.
Press the email account icon.
Press Compose.
Press the required contact.
Press the attachment icon.
Press Attach file and go to the required folder.
Press the required file.
Press OK.
Press Add account.
Press Personal (IMAP).
Press NEXT.
Press NEXT.
Press None.
Press NEXT.
Press None.
Press NEXT.
Press NEXT.
Press NEXT.
