I have problems sending and receiving emails on my OPPO Find X2 Neo
Press Users & Accounts.
Press Add Account.
Press IMAP/POP3.
Press the field below 'Email Account' and key in your email address.
Press Account Password and key in the password for your email account.
Press Sign In.
Press Sender Name and key in the required sender name.
Press OK.
Press Done.
Press the Return key.
Press Account and key in the required name.
Press OK.
Press Sync Frequency.
Press Manual Setup.
Press Advanced Settings.
Press Username and key in the username for your email account.
Press Incoming Server and key in the name of your email provider's incoming server.
Press Security Type.
Press None.
Press Port and key in 110.
Press Outgoing Server and key in the name of your email provider's outgoing server.
Press None.
Press Port and key in 25.
Press Username and key in the username for your email provider's outgoing server.
Press Password and key in the password for your email provider's outgoing server.
Press Sign In.
Press Mail.
Press the new email icon.
Press the required contact.
Press Attach File and go to the required folder.
Press the required file.
Press Add Account.
Press IMAP/POP3.
Press Sign In.
Press OK.
Press Done.
Press OK.
Press Manual Setup.
Press None.
Press Port and key in 143.
Press None.
Press Sign In.
