I have problems sending and receiving picture messages on my OPPO Find X2 Lite
Press SIM Card & Mobile Data.
Press the name of the SIM.
Press Access Point Name.
Press Name.
Press APN.
Press Username.
Key in o2wap and press OK.
Press Password.
Key in password and press OK.
Press MMSC.
Press MMS Proxy.
Press MMS Port.
Key in 8080 and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication Type.
Press PAP.
Press APN Type.
Key in mms and press OK.
Press Save.
Press the message icon.
Press Start chat.
Press the required contact.
Press Gallery and go to the required folder.
Press the required picture.
Press Mobile Data to turn the function on or off.
Press the indicator next to 'Data Roaming' to turn the function on or off.
If you turn on the function, press Turn On.
