My OPPO A54 5G uses a large amount of mobile data
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press Advanced settings.
Press Wi-Fi Assistant.
Press the indicator next to 'Auto-connect to the best Wi-Fi' to turn on the function.
Press the indicator next to 'Auto-switch to mobile network' to turn the function on or off.
Press Notification & status bar.
Press Manage notifications.
Press Location.
Press the indicator next to 'Location' to turn the function on or off.
Press the Return key twice.
Press App management.
Press Permission manager.
Press Location.
Press Play Store.
Press the profile icon.
Press General.
Press Auto-update apps.
Press DONE.
