I have problems sending and receiving picture messages on my OPPO A16s
Press SIM card & mobile data.
Press the required SIM.
Press Access point name.
Press the field below 'Name' and key in O2 UK MMS.
Press the field below 'APN' and key in wap.o2.co.uk.
Press the field below 'Username' and key in o2wap.
Press the field below 'Password' and key in password.
Press the field below 'MMSC' and key in http://mmsc.mms.o2.co.uk:8002.
Press the field below 'MMS proxy' and key in 82.132.254.1.
Press the field below 'MMS port' and key in 8080.
Press the field below 'MCC' and key in 234.
Press the field below 'MNC' and key in 10.
Press Authentication type.
Press PAP.
Press the field below 'APN type' and key in mms.
Press the save icon.
Press the message icon.
Press Start chat.
Press the required contact.
Press the SIM icon.
Press the gallery icon.
Press Gallery and go to the required folder.
Press the required picture.
If you turn on the function, press Turn On.
