I have problems using the internet connection on my OnePlus Nord
Press Wi-Fi & Network.
Press SIM & Network.
Press the required SIM.
Press Access Point Names.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press Save.
Press OK.
Press On/Off.
Simultaneously, press and hold the upper part of the Volume key and keep them both pressed until your phone restarts.
