My Nokia G10 uses a large amount of mobile data
Press Network & Internet.
Press Wi-Fi.
Press the indicator next to 'Use Wi-Fi' to turn on the function.
Press Wi-Fi preferences.
Press Advanced.
Press the indicator next to 'Switch to mobile data automatically' to turn the function on or off.
Press Apps & notifications.
Press SEE ALL APPS.
Press the indicator next to 'All notifications' to turn the function on or off.
Press Location.
Press App access to location.
Press arrow left twice.
Press Advanced.
Press the Google Play icon.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press DONE.
