The battery life on my Nokia G10 is short
Press Accounts.
Press the indicator next to 'Automatically sync app data' to turn the function on or off.
Press OK.
Press the Google Play icon.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press DONE.
Press Apps & notifications.
Press SEE ALL APPS.
Press the indicator next to 'All notifications' to turn the function on or off.
Press Battery Saver to turn on the function.
To end one running application, slide your finger upwards on the required application.
To end all running applications, slide you finger right on the screen.
Press CLEAR ALL.
Press Location.
Press App access to location.
Press arrow left twice.
Press Advanced.
