I have problems sending and receiving picture messages on my Nokia 8.3 5G
Press Network & Internet.
Press Mobile network.
Press Advanced.
Press Access Point Names.
Press Name.
Press APN.
Press Username.
Key in o2wap and press OK.
Press Password.
Key in password and press OK.
Press MMSC.
Press MMS proxy.
Press MMS port.
Key in 8080 and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in mms and press OK.
Press Save.
Press the message icon.
Press Start chat.
Press the required contact.
Press the gallery icon.
Press Gallery and go to the required folder.
Press the required picture.
